Visual Process issue:
On a defined text output, the column width is re-setting to 20 from 254 every time I revise the workspace.
Why is the column width re-setting to the minimum when the workspace is revised?
Hi Cheryl,
It would be hard to say what is going on without seeing exactly what you are doing and having a copy of your process.
I suggest you to open a Support Ticket so that we can investigate this properly.
Thanks!
