Dear ALL
During execution of Process Template, the following error is reported, do anyone encountered the same, request resolution pls
org.mozilla.javascript.WrappedException: WrappedException of encoded string too long: 193151 bytes
while executing
"# Compiled -- no source code available
error "called a copy of a compiled script""
(procedure "::hw::pmgr::PmgrExecutePmgrScript" line 1)
invoked from within
"::hw::pmgr::PmgrExecutePmgrScript $strJSCmd"
("getadvselmethods" arm line 21)
invoked from within
"switch [ lindex $args 0] {
"getadvselmethods" {
foreach {entity} $args break;
if { [string match HmEntSelCol HmMarkCol] } {
*createentitypanel E..."
(procedure "::hw::pmgr::pmt::task3::CollectorHandlerElementshmcol2" line 3)
invoked from within
"::hw::pmgr::pmt::task3::CollectorHandlerElementshmcol2 getadvselmethods Elements"
("uplevel" body line 1)
invoked from within
"uplevel #0 [set ${nsPath}::p_callBack(default)] $args"
(procedure "p_EvalNotifyDefaultCallback" line 3)
invoked from within
"p_EvalNotifyDefaultCallback $nsPath getadvselmethods [ set ${nsPath}::p_text ]"
(procedure "p_GetAdvSelectionMethods" line 17)
invoked from within
"p_GetAdvSelectionMethods $nsPath "
(procedure "p_EntityAdvSel" line 10)
invoked from within
"p_EntityAdvSel .task3.canvasFrame0.canvasBoxFrame.canvasBox.mainWnd._hmcol2.coll"
("eval" body line 1)
invoked from within
"eval p_EntityAdvSel $frame"
(procedure "::hw::pmgr::pmt::task3::p_UpdateCollector" line 27)
invoked from within
"::hw::pmgr::pmt::task3::p_UpdateCollector .task3.canvasFrame0.canvasBoxFrame.canvasBox.mainWnd._hmcol2.coll collector"
invoked from within
(procedure "::hwt::ReleaseCanvasButton" line 1)
invoked from within
"::hwt::ReleaseCanvasButton 0 .task3.canvasFrame0.canvasBoxFrame.canvasBox.mainWnd._hmcol2.coll.colContainer.collectorButton"
(command bound to event)
Thank you,
Arun
