I was hoping that you could clarify some points.Can you confirm whether I should be able to execute a Hyperstudy analysis with RADIOSS?
If it is the case I would be grateful for some tips as I cannot progress beyond a licence error.
RADIOSS runs fine from the Hypermesh session.I get RADIOSS to start but it bangs out with a licence error...
from task_exe_stdout.txt
.. STARTER RUNNING ON 4 THREADS
.. CONTROL VARIABLES
*** Radflex Error : 200 - Back to checkout***
from JOB.out
LICENSE CHECK ERROR
ERROR : License check failed !
'Radioss' feature not found on license server!
Check your License server settings
Many thanks
Mike
