Can someone help me.
I am trying to get component name, material name and component thickness directly into ppt through macro or in hypermesh.
It will be really helpful for reporting purpose.
You can get all these information with a small Tcl script. Write out on Command window and copy/paste into your PPT?
i'm a scripting supporter, but sometimes the function is already there to be used.
In Tools>>Comp Table you will populate a table with pretty much everything that you want.
@adriano a
@nguyen-dai
thanks for your response but i already know the way to check details throught component table what i am looking for is if i run the script in hypermesh it will directly show me assigned material and thickness to displayed components on hypermesh screen
