According to the white paper of Simsolid, volumes, areas, points, can be used as " finite elements" which implies that single volumetric parts can be a finite element.
Why then do we tend to see jagged stress results in different regions of the part, if the part is a single element? I am aware of CAD quality and using the most accurate CAD import settings etc.
Attached are some examples from Simsolid.
