I would like to measure analog input signal (+/-250mV) by the external modulator AMC1304 and be able to display filtered SDFM output bit stream in EMBED. I was able to configure ePWM5A/ePWM5B to generate 50% duty clock 20MHz distributed to AMC1304 (pin 13) and SD Filter Module Channel 3 at F28379D (SD3-CLK). Scoping CLK line shows that PWM works fine and Data line also outputs bit stream. The problem is that EMBED SDFM block outputs nothing.
Could you guide me how configure correctly ePWM and SDFM blocks? Could you share any example of Sigma-Delta measurement in VisSim model?
Attached are my blocks configuration.
Thank you,
Marcin
