Scott, Thanks for showing how to customize the joints. However, how did you create this joint?
Raj,
Select the joint, then view the Motion Rates in the Property Editor.
0 = unconstrained degree of freedom.
My apologies for not suggesting to do that in the Example Model description in the blog article: https://community.altair.com/community?id=community_blog&sys_id=6b1efd41dbfdacd0e8863978f4961962&view_source=searchResult
Scott
Thanks, Scott. I was able to manipulate property editor for custom properties. My question was related to creating the joint in the first place (before assigning the custom properties). I was not able to select the block and pendulum to recognize cylinder or any other joint type.
