Hello
I am trying to simulate a shaft under a shock load which is supported by bearings on two ends .
the shock load is passed to the shaft threw bearings as the bearings are the only supports for the shaft.
the shaft is modelled in 1D . I want to model a bearing to connect to the shaft( 1D elements) at the same time I need to apply shock load at the bearing location only .
can any one please help me in this regard .
