Hi
I am working on sructural analysis of a motor. the motor rotor is a stack of thin plates (0.5mm thk).
Can i model this stack as solid (solid elements ).
As the stack plates are of ekectrical steel (brittle compared to steel) can i take material properties of steel for the same as i dont have mechanical properties for the electrical steel.
