I am trying to convert a thermal analysis model setup in abaqus into optistruct using, TOOL-> Convert command. However, I am ancountering th e following error:
Impossible to help without model.
Kindly give us the information on the Hypermesh version you are using.
Hey,
Try deleting the *FILM loads and then convert.
Let us know if this works.
