I have been carrying out the analysis on the full vehicle and have changed the hard points, mass, spring, moment of inertia (taken from Tools>CG\Inertia Summary) and preload values.I got the following errors in the solving process.
Which parameter do I need to take care while carrying out the analysis.
INFO: Starting SMP run with up to 4 threads.
WARNING: Error in principal J for body [id=10306]: Ji+Jj<Jk!
J=(500, 500, 10000) in body CG principal inertia frame.
Execution continues but the results, if dynamic analysis, may be incorrect!
WARNING: Error in principal J for body [id=20306]: Ji+Jj<Jk!
WARNING: Error in principal J for body [id=10307]: Ji+Jj<Jk!
J=(100, 100, 1000) in body CG principal inertia frame.
WARNING: Error in principal J for body [id=20307]: Ji+Jj<Jk!
