Merge Duplicated Meshes with Pressure Loads
DR31415
DR31415 Altair Community Member
I am looking for a solution or an alternative solution to my question.
Question:
I have two identical meshes in my model. Each mesh has a set of pressure loads associated with it.
Mesh 1 ---> Pressure load Set 1
Mesh 2 ---> Pressure load Set 2
Load Set 1 and Load Set 2 have pressure applied in the same location but different magnitude.
I would like to keep one Mesh, e.g. Mesh 1 and have Load Set 1 and Load Set 2 applied to Mesh 1 only.
Is there an easy way to do this HM?
I have tried 'Tool --> edges --> equivalence' and 'Tool --> faces --> equivalence' approaches which merge the nodes to one set but not the elements. So that Mesh 1 is still tied to Load
Set 1 and Mesh 2 is still tied to Load Set 2. Perhaps I am not doing the process correctly, but any guidance would be greatly appreciated.
  • Q.Nguyen-Dai
    Q.Nguyen-Dai Altair Community Member
    edited April 2020
    • Remove Mesh2 from your model
    • Create Pressure 2 on Mesh 1
    DONE :D/emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' />
  • DR31415
    edited April 2020
    Thanks Q.Nguyen-Dai for the response.
    I probably should have stated that the pressures are imported from bdf file and are not created in HM.
    The only solution I found was by editing the solver deck. I just was wondering if there was a easy way to do with the HM user interface.
  • Q.Nguyen-Dai
    edited April 2020
    If you can share the model, I'll have a look at it.
