Hi everyone,
I am running solid profile extrusion and bearing length opptimization but automated report failed? Why is this?
Best regards,
Report generation is only supported for steady-state analysis and is not yet expanded to bearing optimization and transient analysis. This message should be improved. I will inform the development team to improve the log.
Even if the report generates, it will not have a summary of bearing optimization.
Thank you for reporting this.
Hi Narenda,
I did steady state analysis for solid profile but it don't still have automation reports.
Thanks.
Is there any update regarding this issue?
I have exactly the same problem as Brian.
Thanks in advance
