Hi experts,
I have a trouble about coupling MSMV with EDEM interface. I want to ask how to tranfer rigid tires to EDEM? Can we just transfer rigid tires to EDEM?
I am not certain what you have selected to transfer, but what should be selected and will transfer to EDEM is graphics. Like in the example below. I hope that this helps.
Kind regards
Ignacio
Hi Ignacio,
I used the model in MV libraries. I don't see the graphic of FL, FR tire new. Do I have to import CAD to MSMV? Thank you!
Hi Tuan,
Yes importing a CAD file is what was done in the case shown before I believe. Then you may need to make sure that the graphic is correctly linked to the body that it should be referencing. In that case the body referenced is Wheel-left and Wheel-right respectively, which are part of the wheel body found inside the Frnt macpherson susp folder.
Thank you for your information.
