Engine as RBE2 elements
I am modeling the engine of our frame as a rigid element. I thought of creating RBE2 elements linking the 4 nodes (see the image) :
- 'calculate node' as independant
- 'multiple nodes' (selecting the 4 nodes) as dependant
Of what I understand, the 4 nodes will now be fixed from one another, like a rigid plane.
Is there another method ?
I also thought of another option : creating a rigid 2D plane. I don't know what would be different... But if you could explain how I can create one with these 4 nodes, it would greatly help.
Thanks,
Ben
Hi Ben,
You can find this information on 'HyperMesh 1D Rigids Bars and Beams' helpful:
https://altairuniversity.com/learning-library/hypermesh-1d-rigids-bars-and-beams/
Thank You
