Force Output from enforced Displacement
I ran a model with enforced displacement with SPCD, as explained here:
https://altairuniversity.com/learning-library/how-to-apply-enforced-displacements-correctly/
Then I requested the force as ouput via Global Output Request --> SPCF
The model was just a regular beam and from beam theory the cumulative sum of the force should be around 824.99 N.
In my .out file the force is extremely low and I cannot find the mistake?
The model is in tons, mm, second, so the output should be Newtons.
Thanks for your help everyone.
in the .out file you will find only the summation of the SPCF and as you don't have a 'load' it will be zero.
Request SPCF in H3D and OPTI formats, and you will be able to check the values in each node.
It would be easier to check if you use a RBE2 for apllying the enforced displacement, and then get a single SPCD reaction value to compare with your expected value.
I get better results in a .spcf file now. Thank you.
However, the sum must be close to zero, when only applying an displacement?
For another model, this are the results. I guess the first line is my Loadmatrix at the node? The sum does noe come to zero, is that an indicator for any mistake?
@KemalDemir I used Bernoulli Beam theory for one fixed end and one free end: 6*E*I*w(x) = F*x^2*(3L-x)
Can you share please hand. calc. method ? Because you're using enforced disp. I mean your define directly deflect quantity. You have to go backwards and find the strength. Am I wrong ?
