🎉Community Raffle - Win $25
Join and Win
ERROR 1728 in the input data
User: "Timo Ksr"
Altair Community Member
Updated by Timo Ksr
Hi everyone,
I can not help myself any further with this error:
  *** See next message about line 74 from file:
     MidSurface.fem
   'SET     1       GRID    LIST'
  *** ERROR # 1728 *** in the input data:
  Incorrect SET definition.
Where could the problem be?
I defined acceleration loads.
The sets are called
^accel_nodeset1
^accel_nodeset2
I am doing a topography optimization and defined an functionresponse,
in case this is relevant.
Thank you.
1 - 2 of 21
    User: "Adriano_Koga"
    Updated by Adriano_Koga
    Usually HM doesn't export entities with names starting with '^'.
    Probably that's your case. Try renaming your sets and try it again.
    Otherwise, check if the SET with ID 1 is properly defined or pointing to valid entities.
    User: "Timo Ksr"
    OP
    Updated by Timo Ksr
    Thank you
