select elems/nodes by a window with defined size
User: "jker"
Altair Community Member
Updated by jker
Hello everybody,
is there a chance to select elms or nodes by means of a window that is defined regarding its size?
For example, I would like to select Solidelements on the Surface of the body, that are inside a definde area (circle, diameter 10 mm). Therefore, I would like to use 'by window' 'visible only' 'circle' and define the diameter of the window.
Thanks for any help.
Kind regards
Jo
1 - 2 of 21
