Hello All,
I am facing issue while doing batchmeshing. This type of waviness is there in the washer elements.
Please guide me to resolve the issue.
Sanket
What are your parameter file settings? I am not seeing the same issue
Hello Jason,
In case of flat surfaces parallel to X, Y, Z axes it is working properly. But i am facing issue for inclined surfaces. I am using HM2019.
Hello Jason, In case of flat surfaces parallel to X, Y, Z axes it is working properly. But i am facing issue for inclined surfaces. I am using HM2019. Regards, Sanket
The orientation does not matter. I would upgrade your version as 2019 is pretty old at this point
