Hello All,
I wanted to set environment variables in hypermesh using TCL command. Process i want to do is explained as below,
1) I have one file path {c:\xyz\ref_file.csv}
2) In hypermesh session, lets call this session as "session1". store file path mentioned in step 1) in environment variable using tcl command.
3) Use the value of environment variable in the session1.(currently i am not able to do this)
4) If i open another hypermesh session named as "session2", in session2 i can read value of environment variable which is set in "session1"
So, is there any way so that i can use environment variable in the same session in which i am setting it?
Please guide me to resolve the issue.
Thanks in advance.
Sanket Patil
