Hello All,
I want to add data to in particular row and column in csv file using tcl. How to do that?
Please guide me for the same, Thanks in advance.
Thanks and Regards,
Sanket Patil
Hi Sanket,
I have created the Tcl code(Attached) for your request. You have to specify the row, column, value to be replaced.
Make suew name of your csv file as input.csv or change the variable in code.
It will create a new csv file as output.csv with the repalced values you provided.
I hope it will help you. If you find any difficulties and error in using my code ,please get back to me I will help you.
Manoj M
Hi Sanket, I have created the Tcl code(Attached) for your request. You have to specify the row, column, value to be replaced. Make suew name of your csv file as input.csv or change the variable in code. It will create a new csv file as output.csv with the repalced values you provided. I hope it will help you. If you find any difficulties and error in using my code ,please get back to me I will help you. Regards, Manoj M
Hello Manoj,
Thanks for the help. Can you please resend the code file as i am not able to download it?
Thanks and Regards.
Sanket
Hello Manoj, Thanks for the help. Can you please resend the code file as i am not able to download it? Thanks and Regards. Sanket
PFA
Thank you so much for the help
