search a componet using loop
sanket_patil
sanket_patil Altair Community Member
Hi All,
I have changed Id of a component in hypermesh  and i have a .csv file which contains component's Ids and their thicknesses. Now i want to search component,s id in .csv file and corrosponding thickness value from csv.
Can anyone tell me how to do this using tcl?
Thanks,
Sanket
  • QuyNguyenDai
    QuyNguyenDai Altair Community Member
    edited February 2019
    If I understand correctly you want to search within CSV file from Hyperworks?
  • sanket_patil
    @Nguyen-Dai
     yes
  • QuyNguyenDai
    Tcl can read/write/search within CSV file. And you can run Tcl script from Hyperworks.
    So I think it's possible.
  • Imoto
    Imoto
    @sanket_patil
    Yes it is possible with Tcl.
    Which solver(User profile) are you using?
    Thanks,
    Imoto
  • tinh
    tinh Altair Community Member
    Hi
    Example csv file:
    CompId,Thickness
    1001,1.0
    1002,1.2
    2001,2.0
    2002,2.2
    2004,2.5
    This is a sample code
    set myfile c:/afile.csv
    set fpt [open $myfile]
    set cont [string map {, ' ' \n ' '} [read $fpt]]
    close $fpt
    set MyCompId 2002
    set Thickness [dict get $cont $MyCompId]
  • sanket_patil
    @imoto
    I am using nastran profile.
  • Imoto
    Imoto
    @sanket_patil
    Tinh is already gave you the good example:-)
    -Here is my example-
    # Auto property creation #
    *evaltclscript 'AutoPropertyCreate.tcl' 0;
    *evaltclstring '::autoproperty::Main' 0;
    # Thickness update from CSV #
    set ft {{'CSV Files' .csv} {'All Files' *}};
    set fn [tk_getOpenFile -filetypes $ft];
    set fh [open $fn r];
    while {![eof $fh]} {
     gets $fh line;
     lassign [split $line ,] cid T;
     if {[hm_entityinfo exist comps $cid -byid] == '1'} {
      set pid [hm_getvalue comps id=$cid dataname=propertyid];
      *setvalue props id=$pid PSHELL_T=$T;
    close $fh;
    If you are not using PSHELL card, you have to change the attribute name.
  • sanket_patil
    @imoto @tinh @Nguyen-Dai
     Thank you so much for help. It is working good.
    Sanket
