Solution Method
User: "pmcardle"
Altair Community Member
Updated by pmcardle
I have a multilayered nano antenna that I want to simulate in the THz frequency range. A thin layer of platinum on a silicon core, I originally used the SEP to simulate the platinum and silicon layers but would like to bench mark it against a volumetric solution method ( FEM/VEP). Reason being the platinum layer thickness is less then the skin depth at the frequencies I am simulating. The Mesher does not like the platinum layer so I am stuck. Any suggestions are on a way to ensure my original results with the SEP are accurate independent of using the FEM/VEP?
