Are there material specific modifications to the the meshing rules for the SEP? I ask because when I switched from using a PEC to a dielectric while using the same meshing size I received errors indicating the mesh size was to large. I know for the volumetric solvers it depends on the effective wavelength in the medium, is it similar for the SEP?
Cheers,
Patrick
