Hi experts
When I am trying to set up a Normal Modes analysis in HyperMesh, I am not able to select EIGRL as a card Image. Why not?
Are you sure you are using the OptiStruct user profile while modeling your analysis?
Can you double check?
Yes, That was it. Thank you.
I'm having the same problem in HM version 2022.3 while I'm using OptiStruct user profil.
Do you have a solution ?
Samuel
you need to use a Load Step Input in more recent versions now
Perfect.
Thank you Jasen.
