In HyperWorks I create a session that has a number of windows which maybe Hyperview and HyperGraph windows.
I setup my post processing session for a single solution load case (in my example from LS_Dyna) and then save the session as a template.
I want to run this template to generate exactly the same post session for a number (or many) of the same model undergoing a different load case.
I can do this through the flexible reports interface no issue, however I have to do this independently for each of my load cases (i.e. fill out the paths for graphics file, results file and plot file) which is tedious. I want to automate this across any number of load cases without having to manually fill in the paths.
I believe this is possible to automate using TCL and HWC scripting which I have been playing with, but have not yet managed to get to work.
I found the following video on Altair How-To Youtube which appears to do essentially exactly what I need to do, however unlike the HyperGraph only example shown, I also want to build my HyperView windows as well.
https://www.youtube.com/watch?v=uMeBNfEeIAk&list=FLvTNzGdQA65jXsoO8SAaASA&index=1&t=46s
Using the script shown in that video and modifying it for my session, I generated this tcl script which does not work (in my case I have 5 directories each with a solution set in them)?
set ApproachDir [tk_chooseDirectory]
cd $ApproachDir
set RunDirList [glob -types d *]
foreach RunDir $RunDirList {
hwc open parameterizedsession add "C:/Working Folder/Template.tpl"
hwc open parameterizedsession append Template GRAPHIC_FILE_1=$RunDir/Bracket.k RESULT_FILE_1=$RunDir/d3plot PLOT_FILE_1=$RunDir/binout0000
What am I doing wrong?
Any help would be greatly appreciated.
Thanks.
Richard.
