Hi community.
Bernt Isaksen
Bernt Isaksen Altair Community Member
edited June 2021 in Community Q&A
I have read a NASTRAN bdf file into Hyperworks and done some smoothing and optimization on the mesh.When I try to run the optimized mesh, I get the error: Incorrect data in field # 3. Field 'PID' of CTETRA bulk data. When I check the element, i can see that field 3 has a value of 0. Why?
  • Adriano_Koga
    Adriano_Koga
    edited June 2021
    As you have remeshed your previous mesh, you probably lost your property (PID). I imagine that your previous model had a direct assignment for the properties on the elements. Once you have remeshed, this was lost.
    One good approach is to have a 'indirect' propperty assignment, assigning the property into the 'Component', so that even if you remesh, the property is kept.
  • Adriano_Koga
    Adriano_Koga
    edited June 2021
    by the way, this should be moved to Altair Products. :)
  • Jason_Craanen
    Jason_Craanen
    edited June 2021
    You can also check this is the preferences. This will keep the PID on new elements.
  • Bernt Isaksen
    edited June 2021
    Thanks for your help.
