When I want to run Optistruct and export my model with nodes, BC and elements, the exported Input file has no elements. Why??
HI
by any chance you are selecting displayed, and none is displayed in fact.
or you are using custom option and the entity are deactivated?
Regards
HI by any chance you are selecting displayed, and none is displayed in fact. or you are using custom option and the entity are deactivated? Regards
also, check if your components has no '^' in the beginning of its name, as this won't be exported.
