Hi guys! I tried to use CROD elements for curved lines generated by spline, and it did not work.
And it gives me displacements like this
Why do elements not work together? I want to model the curve using 1D elements.
Thank you!
Vladimir
Hello
CROD elements only have axial and torsional degrees of freedom
https://help.altair.com/hwsolvers/os/topics/solvers/os/crod_bulk_r.htm?zoom_highlight=crod
Please try a CBEAM/CBAR element instead
https://help.altair.com/hwsolvers/os/topics/solvers/os/cbeam_bulk_r.htm?zoom_highlight=cbeam
You can review the different element types here
https://help.altair.com/hwsolvers/os/topics/solvers/os/elements_user_guide_os.htm#elements_user_guide_os
Hello CROD elements only have axial and torsional degrees of freedom https://help.altair.com/hwsolvers/os/topics/solvers/os/crod_bulk_r.htm?zoom_highlight=crod Please try a CBEAM/CBAR element instead https://help.altair.com/hwsolvers/os/topics/solvers/os/cbeam_bulk_r.htm?zoom_highlight=cbeam You can review the different element types here https://help.altair.com/hwsolvers/os/topics/solvers/os/elements_user_guide_os.htm#elements_user_guide_os
Thank you! For some reason, I thought the CROD was more complex. I have never used it before and decided to try it because I wanted to use it for a simple optimization example. I will change to beam elements.
with PBEAM and PBEAML everything works perfect.
