Hi ,
How to Check the Probe Point Results in Hyper-works ?
Are you referring to HyperWorks CFD / AcuSolve point probe? If yes, you should see point probes in the model tree of the Plot Tool:https://2023.help.altair.com/2023/hwdesktop/cfd/topics/pre_processing/solution/plot_run_time_data_t.htm#plot_run_time_data_t
No, I am Using hyperworks for drop test analysis non linear analysis
