Is it normal for a volume mesh to have free edges?
The volume mesh is closed. Why is the free edge detected?
Thanks a lot.
Liming Li
check for some problems connected to mesh quality (eg. duplicate elems, very small edge lengths etc.)
Best regards
Oskar
Hi, check for some problems connected to mesh quality (eg. duplicate elems, very small edge lengths etc.) Best regards Oskar
Thank you for reminding.
There is no problem in duplicate and conncectivity.
The target element size is 30000, and the smallest edge length is 12747. There should be also no problem in this respect.
Liming
Hi
Yes, it is.
You just need to ensure your volume mesh has no free faces inside, and covering faces have no T-connection
Free edges are edges that are not shared by elements.
Hi you
Yes, it is normal. Free edge have exist because those element edge have not equivalent any element. So it appear free edge. But in volume mesh should check by "Face" option which ensure inside mesh not separate.
