As I try to do Hyperstudy setup for parametrized model,
after the nominal run. The out file is created and I can see the stress results there but as I want to create an output response,
The responses can not be read by hyperstudy results reader from the out file in approaches>m1> run01 only text extraction appears.
What can be the problem?
Thank you
