Hypermorph Distribution problem
I want to move a hole located in the middle of a beam. As I translate the elements of the hole along x axis, I want that the disturbance of the elements are distributed equally to the elements which are in the translation directionso that the meshes are not distort.
Is there a way of selecting constraints to equally distribute the disturbances?
Thank you
As I translate my shape with my handles only the next mesh on the translation axis has all the disturbance, I want to distribute this disturbance to the other meshes on the axis. Then this makes mesh distortion as I try to make a shape optimization so my optimization terminates due to mesh distortion.
I am searching for an option on hypermorph.
Thank you
Hi cemreyvz
Can you please send a screenshot of your error or the model
