If someone will be asked if it is possible to generate animated plots with Compose, the answer is 'Yes, sure!'
Try the attached script, which draws the root locus and the homogeneous response of a mass, spring, damper system with varying damping ratio.
Thanks, L Moretti. That's a really cool and useful example with a time delay in drawing and repainting in different colors.
BR, Ronald
BR, Ronald
