I'm looking to determine if the clamping force of a bolt is enough to prevent a piece from sliding down. See the sketch for visual.
The bolt has a collar on the inside of the shape, and a washer on each face outside. Tightening the bolt would prevent the green section from sliding down when loaded from above.
How do I set up this simulation?
