How do I perform element quality checks in Hypermesh 2023?
Hello @Michael Hordon ,
element check is done through the "By element quality" view from version 2023:
You can modify directly in the legend the threshold values for any criteria if needed.
You can also click on any criteria in the legend to focus on this criteria only. If doing so, you can do some iso plot (keeping visible only elements failing the criteria, all other are transparent):
Hope this helps,
Michael
