Change measures background color and make default
How do I change the background of a non-transparent measure entity in HyperView? I'd like to change the dark blue background of the measure in the graphics window in the attached image to something else. Also, is there a way to save the measure display settings such that new measures will display with my desired format?
Thank you,
Mandy
Hi Mandy,
You can switch ON the Transparency field to get Transparent background instead of blue.
You can change the color of the font by clicking on color field and select which ever color you like. See the image below.
Thanks
Rajashri
Thanks for the visual Rajashri. I would like to preserve the background of the measure, but change the color from blue to something else. Do you know how to do that?
Currently, Blue and Transparent color is available. Text color you can change.
Thanks
Rajashri
Hi Mandy,
Thanks
Rajashri
