Line Connector Settings
Mandy Kramer
Mandy Kramer Altair Community Member
edited January 2024 in Community Q&A
I'm trying to create a connector that I can toggle between RBE2/shell generation, and I can't figure out how to get either of them to realize properly.
Which connector setting controls the RBE2 attachment on the outer edge/surface? I'm trying to create RBE2 elements as shown in dotted orange, but the red RBE2's are what I'm getting with the settings shown below. Note that I want to avoid creating RBE2's in the green arrow directions shown:
I have not gotten a successful realization with the shell LTB connector. The brown part is a thin shell layer that envelopes a tetramesh solid (2nd order elements), and when I try to generate a shell LTB mesh from the first order blue shell mesh I get this error. Since both components have material and property assigned, I don't know what to try next:
Here are the LTB connector settings:
  • Paulo  Libório
    Paulo Libório New Altair Community Member
    edited January 2024
    Hello Mandy,
    Is the brown shell component attached to the solid mesh beneath it? What is its thickness?
    I see that for the LTB connection, you're using vertical + angled. Is this the intended result?
    The links in the connector are the shell components, right?
    I mocked your model up, but feel free to share it if you're able.
    Kind regards,
    Paulo Libório.
  • GTT Johan
    GTT Johan
    edited January 2024
    Hi Mandy
    you can also try to create the link to the underlaying solid part/comp
    In my case solid tet mesh to 2d shell , connected with RBE2
