I'm using part assembly representations on a project and have a couple of questions related to .hm file management:
Thank you!
-Mandy
Hi Paulo, Thanks, I'm doing great! Hopefully you are too. A couple of follow-up questions and comments: 1. My goal is to have another person working in one of the representation .hm files while I'm working in the master model. I pictured that this other person might want to have representations within their subassembly, but I understand that this is not recommended and I should only have representations inside the top level model. 2. I've found that when I save the representation .hm file I get an error unless the top level model is closed. Is it possible for somebody to work in the top level and representation level files simultaneously? 3. Is there a way to load a representation into a top level model that was generated external to it? In other words, if the file name and location isn't the only information that's referenced, is there a way for me to load an externally copied representation into the model? Thanks, Mandy
Hi Paulo,
Thanks,
Mandy
Hi Mandy,
I believe most of these have been answered by Jason, but for the sake of continuity of this discussion, here you go:
Hope this helps!
All the best,Paulo Libório.
Hey Mandy, hope you're doing well!
Let me know if I missed something!
Best regards,Paulo Libório.
Paulo,
Yes, my questions were answered by Jason. Thanks for following up.
