While using TCL commands, how can I get the minimum (maximum) ID of selected entities (elements)
Ulrich W.
Ulrich W. Altair Community Member
edited December 2021 in Community Q&A
Hello, first please excuse if I post a question already answered earlier.
While programming a subroutine in TCL for automisation purpose, I need to get the minimum ID of elements (displayed, selected, or grouped) stored in a variable.
In further steps all attached elements to this element shall be moved to a new component in Hypermesh.
If any one could help and provide a solution I would be very glad.
Thank you in advance.
Ulrich
Welcome!
  • Ben Buchanan
    Ben Buchanan
    I think I would just do an lsort then get the first one in the list.
  • Hypermesh User
    Hypermesh User Altair Community Member
    Hi Ulrich,
    Please use the below code for your problem.
    eval *createmark elements 1 "displayed"
    set Maxeleid [hm_entitymaxid elements 1]
    eval *createmark elements 1 $Maxeleid
    *findmark elements 1 257 1 elements 0 2
    set adjele [hm_getmark elements 2]
    set countlst [llength $adjele]
    for {set i 0} {$i < $countlst} {incr i} {
    lappend Maxeleid [lindex $adjele $i]
    *collectorcreateonly components "New_Collector" "" 11
    hm_createmark elems 1 $Maxeleid
    *movemark elements 1 "New_Collector"
    Please reply if you face any issues.
    Manoj M
  • Ben Buchanan
    Ben Buchanan
    Hi Ulrich,
    Manoj M
    Nice Manoj.  I didn't know about the hm_entitymaxid command. Looks like it is also not documented.
    Looks like there is an hm_entityminid command also.
  • Hypermesh User
    Dear Ben,
    I am glad that you have learned new command from me.
    For documentation please check below link.
    https://2020.help.altair.com/2020.1/hwdesktop/hwd/topics/reference/hm/hm_entitymaxid.htm?zoom_highlightsub=hm_entitymaxid
    Yes, As you said hm_entityminid is also there.. please explore..
    Manoj M.
  • Ben Buchanan
    Ben Buchanan
    Dear Ben,
    Manoj M.
    Thanks.  I searched for entitymaxid and it didn't come up.  When you search for hm_entitymaxid it does come up.
  • Ulrich W.
    Hello Manoj
    thank you very much for your help.
    I´ll include the commands into my procedure
    I´m sure they will work, if I had described my problem correctly.
    Regards
    Ulrich
  • Hypermesh User
    Hello Ulrich,
      Please mark as a correct answer if it works correctly ;-)
    Manoj M
Welcome!
Welcome!
