Hi everyone,
i want to solve this problem where there are forces on the 4 point and check the FBD forces at the constraints. i run it in the solver optistruct and got the result. When i open the fem and op2 file in hyperview to check the FBD then it opens the file but when i select an element or node an error message showing 'no valid cross-section for plotting' and doesn't work.
