Hi Everyone,
I have a problem where i have applied the forces in the y direction on four sides of a beam and then i need to study the reaction forces and moments which are caused by these forces at the constraints points. I have used GPFORCE card in order to get the result but when i observe the result the values seem to be strange and unpredictably high. May i am not view the result in a correct way. Can someone suggest me how should i set the FBD pannel to get the forces & moment on the SPC base because of the applied forces. Also what is the different in the FBD plot for Free body force/moment and Resultant foces7moment and what does the ignore node set used for.
Thanks in advance.
