   	I designed a 1-phase transformer on Flux2D and did an open circuirt test. However, I don't have exactly the expected results for the current (magnitude and phase) in the  stator winding, which I explain by the fact that there is no eddy current in the iron magnetic core. Yet, I indicated the conductivity and the complex relative permeability for the iron. I gave the frequency at the beginning.
   	I checked the example available on Flux3D with a 3-phase transformer, but there is no current in the magnetic core.
   	So, my question is how to get the eddy current in the magnetic core in the post-processing. I already tried to put a stranded concuctor coil in the stator core and in the rotor core with a precised current (obtained with the software FEMM),it improved a bit my results but i am not satisfied with it. I also tried to put a resistor in the core but it didn't improve my results.
   	Thank you in advance.
