Hello
 I have an issue with defining ftiction in a shock absorber.
 I modelled the airspring and damping forces as SpringDamper element.
 Then I wanted to include sealing friction. So I created 2 bodies and places a translation joint.
 My idea was to use the friction tab panel in the joint to include a friction which depends on the airpring value during compression.
 However, there is no way to define as an expression the preload field.
 Any idea or workaround?
