I am using polybeams. The problem is I can see them when I load the mdl. When I load the h3d they are not present. Even in the xml file, I cannot see a reference to their stiffness properties.
Any hint? I am using MV 2021
Hello Luca,
You should add a tube graphic for the h3d animation when you are using the polybeam.
