I have a problem which is btw also present in HFSS. Boolean operarions with non-entity, or entities with Zero-dimension at the output throw an error.
 Like when two intersecting parametric objects do not meet there should be nothing in the 3D space, only the operation in the hierarchy list.
 And it is normal because that may be a solution to the optimization.
 But instead, 3D engines refuse to work and make you suffer.
 Is there a way to avoid it in FEKO? In HFSS I was making sophisticated if-then conditional moving of all the parts outside of the solution volume. But in FEKO it seems not applicable.
