Good evening,
I am modelling a kind of no-load transformer : 2 limbs, 2 windings, and 4 grain oriented sheets stacked in each limb, with a step-lap joint. Neumann boundary conditions at the end of each limb.
If the supply of the windings is directly done with a current (in winding's volume region properties), the path of the current in the winding seems correct.
But if the supply is done with a coupling circuit (voltage source followed by two coupling components, one for each winding), the path of the current in one of the windings seems wrong.
(The colors are not the same between these two pictures, but the physical properties are).
Do you have an idea of the reason of the difference of behaviour between these 2 cases, please ? Is it related to a problem with coupling circuit, or anything else ?
I cannot post the files in attachment, the total files size is 96Mo.
Thank for your help,
Ronan
