Hi, i have calculated the laminate homogeneized properties and i would like to atributte this properties to my blank, in order to perform a double forming process. Is that even possible?
Hope someone can help me.
Thanks !
Yes, u can model laminate material as blank via single action, double action, triple action or any other tool setup u want. to make ur blank laminate use layered option in blank configuration.
