Hello everybody,
The corner data takes into account the closest integration points in order to integrate and calculate the stress. We are not able to retrieve the results of integration points inside Compose, but only the stress of the centroid using commands such as readcae, readvector or readmultvectors.
I'm reading stress values from CAE file and writing in H3D file without corner data. For example, I have obtained the stresses of my model and I have written stresses (after post-processing) in H3D file with two matrix:
1. Element ID
2. Stress of the centroid
So I have the next question: it is possible view my results with corner data with only results on the element centroid in compose?
Thanks you very much in advance,
Best regards,
Adrián
