Getting Segmentation Error in Scripting
User: "Sagar Motwani_20540"
Altair Community Member
Updated by Sagar Motwani_20540
I have come across 'Segmentation Error' in my script. Script is for seleting particular surface elements and remeshing it with Spline option, and deleting prev. elements on user satisfaction. The script seems to be fine in context of Syntax and API uses. It would be helpful, if someone could tell me the common causes for this error. And, better, if someone could suggest solution to this problem. We thought it as error caused due to memory limitation. So, we have also used *clearmark every now and then. But, seems to not affect that much.
Thanks,
SAGAR MOTWANI
1 - 1 of 11
    User: "tinh"
    Updated by tinh
    Show the script if you want us to help.
